quick question
8 replies to this topic
#1 ightenhill
ightenhill
    Mechanic
  • 17 posts
Posted 09 February 2016 - 10:22 AM
Im assuming when I order - the download is the latest release and I only need to add any new cumulative updates each week or is it trickier
  • 8,103 posts
Posted 09 February 2016 - 12:21 PM
The main build and a weekly update is all that's needed. :)
#3 ightenhill
ightenhill
    Mechanic
  • 17 posts
Posted 09 February 2016 - 12:51 PM
Thx... Order incoming
#4 ightenhill
ightenhill
    Mechanic
  • 17 posts
Posted 09 February 2016 - 05:15 PM
One issue.. I dont see any track anywhere.. Do I need to dl scale rail separately
  • 8,103 posts
Posted 09 February 2016 - 07:04 PM
Yes. ScaleRail is separate and is required.
#6 ightenhill
ightenhill
    Mechanic
  • 17 posts
Posted 10 February 2016 - 12:18 PM
Thx Marc. I installed all the scale rail options and the track has appeared... I do have some issues though where the track just then disappears/runs out (crossing bridges etc).. Im wondering if its either because Im using OR or its simply because I cant find many details as to whats pending/unfinished etc.. Then again maybe I have done something dumb in my installation... I have mainly used RW or trainsim 2017 (or whatever they have decided to call it this week) before so Im a bit behind (if that makes sense) with MSTS and its setup.
Anyway well done - the quality of this work puts the plastic look of RW to shame...
#7 Bananarama
  • 8,103 posts
Posted 10 February 2016 - 03:02 PM
Track is complete and should be visible. Have you looked through the OR error log?
#8 ightenhill
ightenhill
    Mechanic
  • 17 posts
Posted 10 February 2016 - 04:55 PM
Think I may have solved this down to the fact the laptop may be struggling with the amount of work.. No probs on the main PC and I installed the same way. I did try increasing some view distances in OR on the laptop but that caused a crash. Log below.
loading  TRK TDB SIGCFG DAT ACT RDB
Warning: Track node 1617 pin 0 has invalid link to track node 0 in C:\Program Files\Train Simulator\ROUTES\Cheyenne\Cheyenne.rdb:line 13538
 CARSPAWN SIGSCR sWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Warning: Access to the path 'C:\Program Files\Train Simulator\ROUTES\Cheyenne\Cheyenne.tdb' is denied. Cannot get MD5 check of TDB file, use NA instead but server may not connect you.
 ENV SIGCFG SIGCFG TTYPETTTTTTTTTTTTTTTTTTTTTLLLLLLLLLWWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSWWWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSSSSSWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSSSWWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSSSSSSSSSSSWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWWWSSSSSSSSSSSWWSSSSSSSSSSSSSSSSSWSSSSSSWWWSWSWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSSSSSSSSSSSCS
Warning: 3 missing Stream(s) in C:\Program Files\Train Simulator\trains\trainset\SLI_GREENRIVER_ENGINES\sound\EMD645E3_ext.sms:line 320
CSCS
Warning: 4 missing Stream(s) in C:\Program Files\Train Simulator\trains\trainset\SLI_GREENRIVER_ENGINES\sound\EMD645_ext.sms:line 317
CSCSCSCCCSCCCCCCCCCCCCCCCCCCCCCCCCCS
Warning: Skipped texture with error: Unknown color channel type 0 in c:\program files\train simulator\trains\trainset\sli_greenriver_engines\cabview\blank.ace
Warning: Skipped texture with error: Unknown color channel type 0 in c:\program files\train simulator\trains\trainset\sli_greenriver_engines\cabview\night\blank.ace
Information: Game.ReplaceState(GameStateViewer3D)  GameStateViewer3D
Loader: Time       = 00:01:20.4307335 ms
Loader: Expected   = 149,507,458 bytes
Loader: Actual     = 248,773,410 bytes
Loader: Difference = 99,265,952 bytes (66.4 %)
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSTTT
Warning: Invalid cue point in wave file; Length 55940, CUE 77998, BitsPerSample 16, Channels 1 in C:\Program Files\Train Simulator\trains\trainset\SLI_GREENRIVER_FREIGHT\sound\x_flange2.wav
TWWWSSSSSSWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSWSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSTTTTTTT
Error: ORTS.Processes.ThreadHangException: Thread 'Loader Process' has hung; the consistent stack trace is shown below:
   at ORTS.Viewer3D.TerrainTile..ctor(Viewer viewer, TileManager tileManager, Tile tile) in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Viewer3D\Terrain.cs:line 151
   at ORTS.Viewer3D.TerrainViewer.<>c__DisplayClass8.<Load>b__1(Tile tile) in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Viewer3D\Terrain.cs:line 86
   at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
   at System.Linq.Enumerable.<UnionIterator>d__81`1.MoveNext()
   at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
   at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
   at ORTS.Viewer3D.TerrainViewer.Load() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Viewer3D\Terrain.cs:line 92
   at ORTS.Viewer3D.World.Load() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Viewer3D\World.cs:line 83
   at ORTS.Viewer3D.Viewer.Load() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Viewer3D\Viewer.cs:line 536
   at ORTS.Processes.GameStateViewer3D.Load() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Processes\GameStateViewer3D.cs:line 128
   at ORTS.Processes.LoaderProcess.Load() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Processes\LoaderProcess.cs:line 155
   at ORTS.Processes.LoaderProcess.DoLoad() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Processes\LoaderProcess.cs:line 136
   at ORTS.Processes.LoaderProcess.LoaderThread() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Processes\LoaderProcess.cs:line 107
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
   at ORTS.ORTraceListener.TraceEvent(TraceEventCache eventCache, String source, TraceEventType eventType, Int32 id, String format, Object[] args) in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Common\ErrorLogger.cs:line 124
   at System.Diagnostics.TraceInternal.TraceEvent(TraceEventType eventType, Int32 id, String format, Object[] args)
   at System.Diagnostics.Trace.TraceError(String format, Object[] args)
   at ORTS.ORTraceListener.WriteLine(Object o) in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Common\ErrorLogger.cs:line 206
   at System.Diagnostics.TraceInternal.WriteLine(Object value)
   at System.Diagnostics.Trace.WriteLine(Object value)
   at ORTS.Processes.WatchdogProcess.WatchdogThread() in e:\Documents\Coding\Jenkins\jobs\Open Rails Stable\workspace\Source\RunActivity\Processes\WatchdogProcess.cs:line 131
#9 Bananarama
  • 8,103 posts
Posted 10 February 2016 - 05:51 PM
The only real issue I see is a warning regarding a road track node, but should not prevent you from running the route. There are, however, a few other issues with content not related to Sherman Hill.
