3DTrains
2 Pages V  1 2 >
Reply to this topicStart new topic
> F-Units on full light reflects red on landscape
Jail
post Jan 2 2007, 12:19 PM
Post #1
Brakeman
Group: Valued Customer
Is this something that can be edited ? It goes for all my bought F-Units from 3DTrains
In cabview when I use dim lights its ok. Bright as normal reflections on the landscape, but if I switch to Full all lights that is reflected is red ???
Could this be BIN related ?
P.S. I did a search but didn't find a solution
User is offlineProfile CardPM
Go to the top of the page
+Quote Post
Hack
post Jan 2 2007, 1:15 PM
Post #2
Group Icon
Group: 3DTrains Admin
QUOTE(Jail @ Jan 2 2007, 11:19 AM) *
I'm afraid so.
+Quote Post
clawsonsa
post Jan 4 2007, 5:54 PM
Post #3
Mechanic
QUOTE(Hack @ Jan 2 2007, 12:15 PM) *
I'm afraid so.
Hi Marc,
Any thoughts on how to correct the problem?
Scott
+Quote Post
Huecuvoe
post Jan 4 2007, 7:06 PM
Post #4
QUOTE(clawsonsa @ Jan 4 2007, 4:54 PM) *
After carefully making a backup for the day when this hiccup is fixed in MSTSBin ...
1. Remove the Penalty Sphere of Light AND the Penalty Light in the ENG file.
2. Reduce the total number of lights by 2.
3. Although not absolutely necessary, I also removed the "Penalty" condition from all lights as it was not being used.
Since I have never had a unintentional "Penalty", this was not a big sacrifice.
+Quote Post
GaryG
post Jan 4 2007, 7:11 PM
Post #5
It still appears to be a problem with MSTSbin 1.7.010302highmem.exe...
The Red lighting reflection appears even with the lights off.
For all the other improvements given to us by MSTSbin, I can put up with this minor glitch that appears to be affecting simulated MARS lights, other headlights appear ok.
GaryG
+Quote Post
boubou
post Jan 5 2007, 5:34 AM
Post #6
Hi,
I have the bin version 1.6.122319 and I have the same problem with the light. I think I gonna wait for the next version that I hope the problem wil be fixed.
Boubou
Canada.
+Quote Post
Hack
post Jan 5 2007, 7:45 AM
Post #7
Group Icon
I'll send George a copy of one of the ENG files and see what he finds.
+Quote Post
mdeming
post Jan 5 2007, 5:33 PM
Post #8
I removed just the penalty light, and it went away. Without opening the eng file I believe it was the mars light that I removed. I changed the same parameter to white light but that had no effect at all, but when I removed it it solved it.
+Quote Post
boubou
post Jan 6 2007, 5:43 AM
Post #9
HI,
maybe this is a dumb question but what do you mean by penalty light and where do you find it?
Thanks you very much
Boubou
Canada
+Quote Post
mdeming
post Jan 6 2007, 6:31 AM
Post #10
QUOTE(boubou @ Jan 6 2007, 6:43 AM) *
HI,
Boubou
Canada
Open up the units .eng file with word pad and you will find it in the light section
+Quote Post
akajim
post Jan 6 2007, 8:44 AM
Post #11
QUOTE(mdeming @ Jan 6 2007, 9:31 AM) *
I wanted to see if this worked, and it did. By placing the # ahead of that stream, it is then ignored; no other editing needed.
#Light (
comment( Sphere of Mars Light Penalty )
Type ( 1 )
Conditions (
Headlight ( 3 )
Unit ( 2 )
(IMG:style_emoticons/default/cool.gif) Ron K of Rockford
P.S. I do notice though, that the red warning light is gone when in emergency !!
+Quote Post
GaryG
post Jan 6 2007, 10:58 AM
Post #12
QUOTE(akajim @ Jan 6 2007, 7:44 AM) *
#Light (
Type ( 1 )
Conditions (
Headlight ( 3 )
Unit ( 2 )
Hi
You're probably really confoozing things the way you did the "commenting".
As I see your change, you've commented out the single "Light" line only. To do it correctly, you with the "#", you need one in front of each line of the entire "Light" section for that light. Also, just as important, you need to adjust the number of "Lights" at the start of the lighting section.
You've probably "fixed" the Red by messing up the lighting rather than actually finding a real work-around.
GaryG
+Quote Post
boubou
post Jan 6 2007, 11:25 AM
Post #13
Hi,
thanks you very much for your explanation. But probably I will wait for the next update of the bin.
Boubou
Canada
+Quote Post
Hack
post Jan 6 2007, 11:32 AM
Post #14
Group Icon
QUOTE(GaryG @ Jan 6 2007, 9:58 AM) *
I haven't tried it myself, but isn't the "#" character valid until the closing ")" bracket at the end of the light parameter?
+Quote Post
akajim
post Jan 6 2007, 12:55 PM
Post #15
Like I said, I was experimenting here based on what the problem was (red light reflection on landscape). The reflection is gone, and the gyra (mars) lite works perfectly; just not red warning when in emergency. What more can I say, if it don't sound right; then so be it; just don't do it! I just wanted to share what I tryed.
P.S. This experiment was with the D&RGW F9A 5771 running on Whitefish4 with Kosmos "badlands" environment at approximately mid-day. Further testing running the same on FBL SR with same environment but at dusk, a simultaneous flashing occured in the cab with the rotation of the mars-light; so we can put this one to sleep!!!
+Quote Post
akajim
post Jan 6 2007, 1:28 PM
Post #16
Okay then, by removing that one whole light section down to the next, and reducing no. of lights by 1; I am still getting the flashing in the cab. Back to original eng.file again with red reflection, I am still noticing the flashing in the cab, but now it is red. I am running the Bin Patch1.6.122319XP. So is anyone else noticing this, or is it just me?
(IMG:style_emoticons/default/wacko.gif) Ron K of Rockford
+Quote Post
Huecuvoe
post Jan 6 2007, 1:41 PM
Post #17
QUOTE(Hack @ Jan 6 2007, 10:32 AM) *
I can promise that I don't know, but I always thought the "#" simply commented out the remainder of the line.
+Quote Post
akajim
post Jan 6 2007, 1:42 PM
Post #18
Okay guys! For further comparison testing, I tryed some of Gaetan's ATSF F-units with the "Mars Light"; same route and conditions; and all is fine. No red reflections and no flashing in the cab. Also notice that his eng.file does not have the penalty light section. This is a comparison only, not "Touting" either product as I have and enjoy both immensely!
(IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/cool.gif) Ron K of Rockford
+Quote Post
atsf37l
post Jan 7 2007, 11:03 PM
Post #19
Railroad President
Still sticking with 1.6.09 until this gets resolved. (IMG:style_emoticons/default/wink.gif)
+Quote Post
oldrailfan
post Jan 8 2007, 8:09 PM
Post #20
Registered Ferroequinologist
QUOTE(Huecuvoe @ Jan 6 2007, 2:41 PM) *
Maybe it's not necessary, but I've always used the octograph ( (IMG:style_emoticons/default/ohmy.gif) Big Word!) on each line I wanted to "silence."
Usually what I do, if i want to turn off a light but retain the instruction for later use, is to put "comment(" in front of or on the line above the area I wanted to disable, and then close the parentheses on the line below (NOT the same line) the last line I want to cancel. I find that almost as reliable as deleting. This also works to disable dynamic brakes or a passenger view.
QUOTE(atsf37l @ Jan 8 2007, 12:03 AM) *
Me too!
+Quote Post
2 Pages V  1 2 >
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
3DTrains | All Aboard | Dekosoft | Diesels West | Digital-Rails | Railway Station | Sacramento Locomotive Works | V Scale Creations
Lo-Fi Version Time is now: May 18 2013, 7:46 PM
