OpenRails and A&M
5 replies to this topic
#1 billmoyer
billmoyer
    Brakeman
  • 64 posts
Posted 15 April 2012 - 07:40 PM
I recently installed the latest version of OR on my system. I just tried running the A&M, West Haul 2 and had quite a surprise. I realize the loads of rock to be picked up at the Junction are heavy but, I can't even push them back up the branch to hook up with the grain empties. Is the physics that different in OR? If so, is there a way for a person, who isn't comfortable getting into the program, to adjust the settings? Or, should I just modify the activity to run with three engines? Bill
#2 frog3764
frog3764
  • 20 posts
Posted 16 April 2012 - 03:53 PM
Bill
Hey Bill - If I remember right, the physics on OR are only general and not "tuned" yet.
Jim
#3 longiron
longiron
    Track Layer
  • 11 posts
Posted 17 April 2012 - 11:15 AM
just caught this thread. The OpenRails v0.7 physics model is extremely accurate within the limitations of the MSTS ENG parameters. The results may be different than MSTS. Since MSTS was reasonably accurate, the two should be close. But where the big differences lie is when the physics parameters have been "adjusted" to unrealistic values to make MSTS performance like the real world.
What's different between the two?
First, OR uses the actual Davis equations for friction (i.e. resistance), not necessarily the Friction definition in the ENG file. This may make the train easier or harder to pull compared to MSTS depending on how accuarate the parameters in the Friction section are.
Two, the tractive effort and adhesion are accurately calculated, including wheel slip. check out the youtube vid: http://www.youtube.c...mp;feature=plcp
Third, OpenRails simulates the "loading" of a diesel electric locomotive, rather than the physics performance of an automobile, which MSTS better resembles.
As OpenRails introduces new parameters, this will make OpenRails physics even more accurate including traction motor temp degrading, tractive effort curves, phase transition for first generation diesels, parallel & series motor simulation and much more.
I have A&M, it's one of the core test routes for the OR team. Will give this activity a try over the weekend and report my results
#4 laming
  • 3,552 posts
Posted 17 April 2012 - 04:36 PM
Yes, please do.
#5 wacampbell
wacampbell
    Brakeman
  • 64 posts
Posted 18 April 2012 - 06:37 PM
It sounds like you may not have connected the brake hoses. After you couple, hit the backslash key to connect the brake hose and wait for the train line to charge before trying pull away.
#6 billmoyer
billmoyer
    Brakeman
  • 64 posts
Posted 23 April 2012 - 07:16 AM
That was the answer. I overlooked the "advanced braking" portion of the quick start guide. :( :(
